388bu's LQ4 swap thread - Its alive!
388bu
3,228
Huntley, il
www.shiftn6.com
Doober said:
I came back to read through :D I actually have a question too :p You first said you moved the motor back 1¼", but then went to about ¾". It says in this pic the mounts moved it back the 1¼", what did you do to gain ½" back?
I just drilled new holes in the frame. I had a hard time getting the motor to sit in there using the stock bolt hole locations. I ended up just bolting the mounts to the motor, getting it where I wanted and then scribed the spots for the holes on the frame.
388bu
3,228
Huntley, il
www.shiftn6.com
dirtybird said:
any update on ls7 swap? seeing your car makes want to finish mine.
The motor is taking forever and a day. Its been 3 months since I sat down with Larry over at Speed Inc detailing what I want. Its really close though, im thinking ill get it this week/weekend.
The 6.0 is out and everything is ready, just need the damn motor! Pics to come soon!
Deuce4935
341
Chicago, Il
Considering you've been such a patient customer( and not to mention the coin you shelled out for the LS&), the guys over there at SpeedInc should go ahead and do the install on the house!
