I am trying to find out currently what setup will be best but most likely will run the Camaro setup with the alternator in the lower position. As far as I have found no one has used the LS3 setup in a Gbody so I don't know exactly how this will work yet but I am only doing a little at a time. So far I'm only at maybe 1200 dollars into the build with a ways to go
I have Block w heads/LS3 intake with fuel rails/injectors/LS3 camaro water pump/Ls3 Camaro Crank pulley
so I still need tensioners/power steering and alternator assembly/ coils,wiring,throttle body,pedal and ecm
may just go with GM's kit for harness,ecm, and pedal I dunno yet
-Collin
-Collin
