tiedyemike8 said:I have to agree with Gitdowns.
Don't listen to those guys on Horsepower TV or in CHP magazine. They are paid to advertise parts. Nothing else. It's as simple as that.
If you are building the engine for 400 hp or so, and throw a 150 shot on it, most of the stock parts will live a long time. Just remember that when the time comes that you want to go faster, a better crank and rods will be needed. A factory 400 block is good for 550-650 hp or so. It doesn't matter if it has splayed caps installed and plugged deck and steam holes, 550-650hp seems to be the "safe" limit. That being said, I have seen guys pushing over 900 hp with nitrous using factory 400 blocks. But most of them will tell you that they are really pushing their luck.
With the short block, step 1 is to disassemble the engine to see what you have to work with. Depending on the condition of things, you might be able to just replace main and rod bearings, break the glaze on the cylinders for the new pistons and rings, and install a new oil pump. If the cylinders must be bored, honing with a torque plate isn't necessary for what you are doing. Having the rods rebuilt with good bolts would be a good idea and worth the money. I wouldn't put any extra money into the block. Stay away from splayed caps, you don't need them. Yes, longer connecting rods are always better, but with your goals and budget, don't worry about it.
Forged pistons are great, but hypereutectics are fine for what you are doing. A good friend of mine has been spraying a 383 with hyper pistons with a 250 shot for years now. I was convinced he would burn up those pistons, but he hasn't after 7-8 years now. It's a street car that he often drives to work. He has never had any problems with it.
Don't worry about balancing unless you are going to spin it past 6000 rpm a lot. Running it up to 6500 once in a while will not hurt anything. And I can tell you from experience that with heads under 200cc, 5500-6000 rpm is probably all you will get out of the engine.
As for the upper half of the engine, vortec heads would make for a great, torquey street engine. I would run a flat tappet cam with duration in the 235-245 at .050 range and as much lift as the pistons and heads will allow.
A single plane intake will generally work better than a dual plane on your 400, but if I already had a dual plane, I wouldn't hesitate to use it.
A basic 750 cfm carb is all you need. Carter carbs are great for street cars.
A stock balancer, flexplate, distributer are all fine.
1 3/4 headers might be beneficial, but I can't remember what those vortec heads flow on the exhaust side.
Anyway, thats what I would do if I were in your shoes, but this is just my opinion!
Have to agree. Unless you are going ultra gonzo hi-po you don't need all the super high buck stuff to have a quick ride. Its hard to do at times but my motto is to try not to use the credit card and stay outta the machine shop as much as possible.
