tried another alternator, still charges relatively low. with no fan or water pump running right when i start the car it's around 13.5V. turn on the w/p and fan and it drops to around 12.5V or so. if i turn on anything else, it drops to 12V or less. even the turn signals flashing makes the voltage drop. any thoughts as to what might be causing this? i thought maybe a bad ground, but i'm not sure. i have a ground from the battery to the frame (rear of the car), a huge ground strap from the block to the frame, and recently added a ground from the body to the frame.
