charging problems....still!!!!!!!!!!!
injected
432
Quebec , Canada
Supe said:
After going through the same issue, it turned out to be yet ANOTHER busted Optima battery (#6 now, never again).
Hey had the same problem last year ??????? Never thought about that !!! Your saying you changed 6 batteries??? I replaced mine with a stupid Delco and works fine since and half the price !
grizwald
3,300
Ontario, Canada
i have an ac delco battery too. i don't think that's my problem. it holds the charge fine and starts without any problems after sitting for a couple weeks or longer. in fairness, the alternator i have is old. just seems odd that i've tried 2 different alts (both used ones) and have had the same charging. still haven't messed around with any grounds yet, so i'll see what happens with that.
Supe
15,116
Charlotte, NC
1-5 dead, on #6 now.
SSmonte408
147
otisville, Michigan
thats the problem i'm having, I have a redtop. It will take a charge from a battery charger, but it will slowly die when I try to drive it. been through 4 100 amp alternators.....starting to think its the battery.
Supe
15,116
Charlotte, NC
I'm telling you man, I tried EVERYTHING. They tested the battery as "good."
It was the same thing. Car at 13.5 on startup, drops to 11 and change with everything on. I changed everything from battery cables, added grounds, ran a 6 gauge alternator lead straight back to the battery, same thing. Replaced battery, 14 and change on startup and barely dipped with everything on. I will never buy another Optima.
