LS6 Tommy said:Tech tip: If you are looking for 12 inch discs off of a donor car, do not use police or taxicab spindles. The lower ball joint tapers are too big and will not work. The ball joints for those vehicles can not be machined down to fit your control arm either.
Astro van use the same spindles. Its possible to use them like I did. I whipped up some thin sleeves.
It's roughly 3/8", not 1"...
X2. On my Olds anyway even with the wider track I had less tire rubbing do to the neg camber curve.
Imo I wouldn't do the b-body swap if the added bump steer isn't corrected.
