Possibly converting to a 4 speed! But I have some questions
mongoose
15
i dunno if muncies will be the same length... i know my saggy is... but someone told me i needed to shorten mine when i was going to switch over to a muncie....
I bet it would have even better clearance with the kit (from the Z bar) Forgot who makes it, but 80eclt or Doober may remember, it's like 65.00 and has the heim ends.
Trickbu
I actuallly had a post going about it yesterday, but I accidentally closed the window & I had so much written I just said @$%# it. http://www.speeddirect.com. Just click the pic.
That's the one! I gotta get one of those myself.
Trickbu
StreetBu
4,158
3
Upstate NY
I have a Muncie M-21 in my car, replaced the blown t350, no mods to the driveshaft or crossmember, bolts right in. Same length as a Saginaw
Streetbu,
How about the shifter, does it come out the same place in the tunnel as the stock saginaw location?
Trickbu
StreetBu
4,158
3
Upstate NY
I'm not positive, mine doesnt, but mine isnt a stock muncie either, it's had a spacer machined for the shifter to move it out to the side to make all the shift linkage straight and use rod ends.
HarrisonTX
3,332
Burleson TX
t5montecarlo said:
Doober said:
You have a choice of painted, ceramic coated, or stainless (didn't have stainless when I got mine, probably would've gotten those instead).
http://store.summitracing.com/egnsearch.asp?N=700+300760+4294908216+4294925046+4294840140+4294799365+4294791244+115+4294908177
According to the detail of this part, it will not work:
Standard Transmission Floor Shift = No
How well do they fit with the linkage?
Are you certain this is the same part you have installed?
T5 Monte, and streetbu.
I would at least try those headers. If the header company dosnt have a "standard transmission floor shift" g body around to test fit that part number header, then they just say "no, it wont fit" to protect themselves. I think you have a chance they will fit.
Im sorry to say i dont have the part number for my headers, they were just some cheapy HEDMANS from jegs for $100.
As for the drive shaft, you will probably have to shorten it. From from an auto, to a 4 speed with a 7.5, i had to shorten. Then when i got my 8.5, i had to shorten it even more.
any other questions.
Welcome to the man pedel club
StreetBu
4,158
3
Upstate NY
Drive shaft and crossmember will bolt right in for a munice, no mods needed.
