setting timing ?
t-money80
33
Granite City IL
Today i was setting the timing on my 350 and when i put my hand on top of the distributor to set the timing the timing mark wound jump all over . I had to push on the vacum advance canister to get it set . With my hand off everthing is stable but as soon as i touch the coil the mark blinks off and on and is not stable . Also when i do this nothing happens to the motor rpm and the car runs ok. What might cause this to happen? Thanks .
Sikmalibu
744
Central NJ
Is the dist loose it might be jumping a tooth. Or maybe the coil is grounding out when you touch it. Its hard to diagnose on the computer.
racecar77
2,438
Crete,IL
What??? That's not even close to correct advice. To jump a tooth the distributor would have to come up out of the block high enough to dis-engage the distributor gear from the camshaft gear. The motor was running.
injected
432
Quebec , Canada
x2
Sikmalibu
744
Central NJ
sorry boys I read it wrong...never again do I leave advice after a long day at work!
Is your vacuum advance canister disconnected? It needs to be disconnected to get an accurate reading. If the car is running fine it may be electricity flowing through you to the timing light, making it act erratic. I always try to make sure I'm touching as little as possible when I set the timing, just to be safe.
TNTS79
1,252
Illiniois
Sounds like the problem is in your timing light or the inductive pick up to me....
Vacuum advance is bad and not holding the ring in the same spot when no vacuum is applied. That's my guess. Pull the advance out of the distributor and see if it has play in it, and if vacuum even makes it work.
injected said:
x2
Don't forget the most important part, you'd lose ALL oil pressure pretty damn quick. :lol:
t-money80
33
Granite City IL
Thanks for the help. The car is running good and it only does it if i touch the coil, (HEI)
if i push on the vacuum advance its is stable. I did have the vac / adv disconnected. Ill recheck everthing and try the light on another car . Again thanks for all the help.
