Tremec TKO 600
Moderator: Moderators
WEBBER
Post by WEBBER » Sun Dec 04, 2005 3:06 pm
Aren't G body clutches 10.4"?
The older I get, the more dangerous, I am !!!!
The only replacement for cubic inches, is rectangular dollar$$$$$$
Post by LS6 Tommy » Sun Dec 04, 2005 3:31 pm
I think I know why you're having problems. It sounds like you bought a "Builder's Series" kit. It comes with a freebie clutch, (probably not USA made, IIRC, Keisler usually uses McLeod) and it says right on the website that the trans tunnel must be trimmed and it may not fit the console. Only the "PerfectFit" kit has the Keisler custom tailshaft/shifter that is a direct fit.
Meat Drapes
Post by Meat Drapes » Mon Dec 05, 2005 7:09 pm
Ah yes, the 'Direct Fit' system from Keilser. Let me tell you, its a myth. There is NO direct fit. Its still a work in progress.
I talked to Keisler today and got NEW info regarding the crossmember. Keilser Engineering HAS NEVER built one for the 79 G-Body before. The CHP article was done on a later model El Camino that has a longer Uni-body style frame. Particularly on the driver side. Keisler is still developing the crossmember for my year. They told me that if I could come up with a suitable crossmember to fit the Tremec they would pay me!! I had told them I was tired of waiting for them to get me a ship date and I was going to modify the crossmember that was holding my Saginaw in. So now I have to get the Tremec installed and brace it with 2x4's so I can take measurements. I think the pad that the tranny sits on only needs to be moved back about 3-5 inches. I am sure a competent welder could handle that if I provide decent measurements.
The crossmember I do have is from the a similar kit that was used in the CHP article. Keisler said I could buy a frame extention from Honest Charlies and try to 'make' things fit. They have not tested this and thought I might be a good guiniea pig. NO DICE!!
In regards to the clutch, it was a 10.4 , I went ahead and bought a Centerforce dual friction setup. Its got to be better then the "Made in China" crap.
Also, the trans tunnel must be cut for even the DIRECT FIT. There is no such thing as perfect fit. Yes the tranny has a big offset, but that still does not quite do it.
Meat Drapes
Post by Meat Drapes » Mon Dec 05, 2005 7:11 pm
Once this is all in, it better be worth it.
Post by LS6 Tommy » Mon Dec 05, 2005 11:05 pm
Interesting. I watched Shafi's guys do an install at Corvettes at Carlisle. It sure looked smooth to me. I had some problems with his stuff, too. When I ordered the conversion "kit" to put my Muncie into my 80, the master cylinder he sent me wasn't even close. I think it was for a gen II F-body. I ended up getting a Mcleod gen III F-body master to go with my John Bzdel pedal. Keisler gave me a refund on the master. All the other stuff looks beautiful. I'll find out when I finish the install.
Meat Drapes
Post by Meat Drapes » Sat Dec 10, 2005 6:47 pm
Clutch is in. 10.4 Center Force Dual Friction. Its perty.
El Coolmino
Post by El Coolmino » Sun Dec 11, 2005 8:59 am
You're having the same kind of customer service that I got from those guys. Good products, but you get a different story every time you call. My trans is prior to their "kit", I'm using a modified G force 2004r crossmember. However, my 81 required the same frame extension you're talking about for the later crossmember. It's a 1x3 piece of rectangular tubing that bolts to the original crossmember mounts, and is about 2 ft long. Also bolts to the frame a little further back, and the crossmember bolts to it. If you've got a hacksaw and a drill, you could make one of these from tubing.
Basically, I wouldn't be afraid to try the frame extension route. I'd definitely start there before cutting into the crossmember.
They may be overblowing the tunnel modification. I had to ding mine in 2 spots and cut the shifter hole. Unless they're using the stock 4 speed pedestal, but those are available all over. Although one of the dings I made might interfere with the flange on that pedestal, it's about the same area. Hmmm...good luck
You'll really like the dual friction, Got about 10K on mine and couldn't be happier. Smooth as butter with mechanical linkage.
The driveshaft thing really suprises me. I thought all G body was the same frame, except elcamino. You'd think if they can make a transmission crossmember that fits, they'd have a pretty good idea of where the tailshaft is gonna end up. But then again, they make custom speedometer cables for everything, instead of one or two mechanical adapters. I use an adapter from Forte's. Think their product line started with mopar stuff, so their technical staff has sort of a reverse threaded approach to start with :D
WEBBER
Post by WEBBER » Sun Dec 11, 2005 9:26 am
Maybe Rick(iceman) could do you some good. As far as crossmember or extention. His ad is on the home page.
Meat Drapes
Post by Meat Drapes » Tue Dec 13, 2005 9:45 pm
I have been bothering Keisler now several times a week. They have finally told me they have a new contract for crossmembers. The last word today was three weeks to get it. We will see. Its a good thing my car has a lot of work being done to it. I can wait that long.
I did in fact contact Rick(Iceman) but have not been able to follow through. He stated that around $150 or so would be the magic number to fab up what I need. Not too bad. If Keisler was going to take more then 3 months I was tempted. But only after I tried to get my original fixed first.
My UMI control arms came in, new Carb is in. Interior rust is fixed, and clutch just needs to be torqued to proper specs. Once a few more things are complete, Ill wrestle the tranny into place and prop it up for the driveshaft measurement.
Now if only I could get Keisler to send me the sheetmetal and template so I can modify the tunnel!!
I have also taken many pictures, just need to learn how to post that too.
Post by LS6 Tommy » Wed Dec 14, 2005 1:27 pm
Meat Drapes wrote:Clutch is in. 10.4 Center Force Dual Friction. Its perty.
Are you running a mechanical linkage? Shafi told me not to use a Centerforce with a hydraulic setup. I can't remember why.
Meat Drapes
Post by Meat Drapes » Wed Dec 14, 2005 4:10 pm
I have a mech linkage.
Why not hydraulic? I wanted to switch someday.
El Coolmino
Post by El Coolmino » Wed Dec 14, 2005 8:50 pm
LS6 Tommy wrote:Are you running a mechanical linkage? Shafi told me not to use a Centerforce with a hydraulic setup. I can't remember why.
I'm guessing here, cause I've not heard that before. But it would make sense, there's probably valving in the slave cylinder to make it disengage smoothly. The release is powered by the pressure plate springs, the slave cylinder just resists the pressure smoothly. Since the centerforce has super light pedal around the floor, I could see disengagement problems with hydraulic. Like I said, just guessing :-s
Meat Drapes
Post by Meat Drapes » Mon Dec 19, 2005 4:05 pm
The clutch was a 10.4 inch. I replaced it with a Center Force Clutch. The Clutch is in and the bellhousing back on. While I was down there I put the headers in, they had to go in from underneath. Once the tranny is in Ill take a measurement for the new driveshaft. I also got the sheetmetal for the new shifter hump. Small cut is required for the new shifter location. Keisler decided not to send the template so I can know where to make the cuts. I called them today, they said they would call me back. Thay did not.
Meat Drapes
Post by Meat Drapes » Mon Dec 19, 2005 4:06 pm
That last post was to answer what I thought was a question prior to the last post...but then it disappeared. I need more beer.
Meat Drapes
Post by Meat Drapes » Tue Dec 27, 2005 7:37 pm
I am still waiting on the template to cut/elongate the stock shifter hump.
I 'attempted' to wrestle the tranny in the other day but the shifter is just aft of the original hole so it would not fit. I am leary to just cut without proper guidance from the template so I am still waiting....and waiting.
GM Synchromesh tranmission fluid... $10.42 per qt. , that is not cheap.
Tremec takes 3 qts.
Post Reply
