Tremec TKO 600
Moderator: Moderators
Meat Drapes
Post by Meat Drapes » Fri Dec 30, 2005 5:56 pm
Template came and it was more of a complicated cut then I thought. Better that I waited. After the metal was cut it took 10 minutes to get the tranny into the car. Once the tranny was in I jacked it up to the tunnel and checked the cut, very nice. I have bent the precut sheetmetal and now need to secure it in place. While all this is taking place I can now take a measurement for the new driveshaft.
Next in the waiting game is the crossmember. Boxed and powder coated it better fit perfect.
I am getting just a little excited.
Meat Drapes
Post by Meat Drapes » Sat Dec 31, 2005 10:57 pm
Jorgemece
Post by Jorgemece » Wed Jan 04, 2006 7:56 pm
I've been following your build up. Keep it up.
I've seriously been thinking of going with a TKO because I just love manual Transmissions. Sorry to hear you've been having a hard time with Keisler.
I was originally thinking of going with a 700R4 but hear many horror stories about the trans....They seem to blow up.
I might just have to wait some time to save up enough money to do the swap. It might just be worth it.
Thanks
Meat Drapes
Post by Meat Drapes » Wed Jan 04, 2006 8:38 pm
I decided to modify the stock crossmember while I wait for Keisler to get their contractors in order. I made a template out of cardboard and "eyeballed" a few dimensions. Then took my handy Black & Decker Jig Saw and cut the 'pad' from the crossmember. Once that was off I chalked up a few lines for the local welder to go off of. The welding shop cut me a new pad out of 3/16 thick sheetmetal to the dimensions of the pad I made. Tacked it on today and I tried it out.
The Cut is perfect. My eyeballing was off 1/2 inch. I need to have the pad slid over to meet the tranny mount and I will be nearly good. The pad needs to have a 'cant' in it as well. I was not able to see this from laying right under the xmember and just drawing lines on it. The pad is also a LITTLE too low as the tailhousing rests on the top of the crossmember insted of the pad. All this will hopefully be corrected tomorrow.
Ill have a pic posted later this week.
My cost... maybe $25. Keisler can kiss my behind!!!! I should have done a T-56 from scratch.
Meat Drapes
Post by Meat Drapes » Thu Jan 05, 2006 10:25 pm
Had the pad moved and 2 small bends put in it. Then I chalked up new lines for the welder. The bends in the pad raised the edge up about 1 1/2 inch. The bends are perfect but I moved the pad too far . With the bends in the pad and me trying to adjust for my first mistake I overshot the movement of the pad and now went too far by 1/2 an inch in the other direction. I tried to compensate for the bends in the pad as they shortened it but its hard to make a good call without ANY type of accurate measurement with just my eyes. Tomorrow I will have it just right. The tailshaft now sits over the crossmember really nice. Once the holes are aligned, Ill be pretty happy.
malihoochie
Post by malihoochie » Fri Jan 06, 2006 8:27 pm
I'm quite interested in your progress as mine has ground to a halt (all of my own laziness). Would love to see your x-member, as this was also my plan. I thought trying to modify my own first would be best before buying one of the premade ones out there & then modifying it for my TKO. Best of luck and keep posting this info.
PS - I'm planning on not using a console, just a shifter boot. Do you think that "hump" they had you use was necessary?
'79 malibu - procharged 400sbc, TKO 600, 8.5" GN rear w/ 3.42's
"Work in progress"
'69 camaro - 2 stage nos bbc,th400,4.10 12 bolt
"Work in progress"
Meat Drapes
Post by Meat Drapes » Fri Jan 06, 2006 10:28 pm
The crossmember is done. I will take a pic and post it here this weekend.
The new hump was definitly necessary. The cut was very precise and required the hump to be moved back a few inches. The sheet metal covers the hole nicely and provides a place for a new boot.. My only wish was that I moved the hump even further back. Maybe another inch or so. As it is now the new shifter boot I have is not centered on the boot.
My main problem with getting more pics posted is I took them with HUGE resolution. I need to shrink them a little so I can have enough room on my website.
Meat Drapes
Post by Meat Drapes » Sun Jan 08, 2006 9:02 pm
I think the 3/8ths sheetmetal will do a fine job intill Keilser gets me the right one.
Malihoochie, who did you get your kit from? I would like to hear about your ordeal.
Once I get the driveshaft I can try to drive it. I am going to get new carpet too. My wife is sick of my car.
malihoochie
Post by malihoochie » Tue Jan 10, 2006 7:36 pm
I bought all my stuff piece by piece from various sources. Got the trans from Liberty (local, yet big name trans shop), bellhousing and z-bar from a friend in a trade, pedals from muscle cars only, linkage from Speeddirect, various parts from a friend at a chevy dealer (ballstuds/synchromesh/etc), clutch and flywheel from Hays, and lots of info from this site and a few others. Elcoolmino was helpful too. I have really been lazy about getting the job done though. :oops: I've got 3 kids and they've been the major distraction from the garage. When its two parents vs. 3 kids the cars get slid to the back burner - but just for the time being. Very interested in your x-member mods. Thanks
"Work in progress"
"Work in progress"
Meat Drapes
Post by Meat Drapes » Wed Jan 11, 2006 5:28 pm
Malihoochie, did you get the tremec with an offset? How much did the total investment end up costing ? What do you have left to do?
I have the engine tuned and just need to adjust my linkage. Seems like I have a very long pedal throw to engage or disengage the clutch. Is there a way to shorten this?
Once I get driveshaft... I CAN DRIVE IT!!!
malihoochie
Post by malihoochie » Thu Jan 12, 2006 10:27 am
MD - My trans is standard, not altered in any way since Tremec built it. Because of this I dont think I need the hump you've added. Elcoolmino has a trans like mine and he says he only needed to convince the floorboard with a couple of well placed hammer blows. I wonder if the shifter stick I plan to use has more offset than yours, to place the knob in the same place after all is said and done. I have not kept up with my total cost to date, but I have spent wisely and have also taken advantage of the it's "who you know" option. I would guess I've got less than $2200 invested so far, I still need some odds & ends though. I will also need to get a driveshaft yet. You ask what I have yet to do - haha! mainly get off my a$$. As well as my trans drama I also have my heads off the car. They have been ported and hopefully will be done and assembled sometime soon. But because my heads are off - so is my supercharger, intake, headers, tubing to the intercooler, etc. :( I predict that I'll punk out 'til the end of January and then bust a$$ in February to have the car out in March. Up here in Michigan the winter is not as friendly as it is in NC. :P But the bad thing is that for the last few weeks it has actually been real mild - and I still have not done anything! :oops:
I am curiuos to find out what you did for connecting your speedo & reverse lights & if you have a neutral saftey switch. Also are you using a pedal stop for the clutch? I see that OPGI offers one (it could be made so easily) and am not sure if I really need it or not. :? . Keep your pics comming!
"Work in progress"
"Work in progress"
Meat Drapes
Post by Meat Drapes » Thu Jan 12, 2006 7:36 pm
I have not connected the speedo yet. Not sure if I was going to. I need a new one as mine has stuck odometer and causes the needle to bounce. It drives me insane... sounds like a turn signal is on all the time.
The reverse lights do not connect directly like Keisler said they would.
The neutral safety is factory wired and does not seem to deal with the tranny just the pedal.
My driveshaft is on a FED EX truck right now. I hope to GOD it comes on friday as I dont think they deliver on Sat and its a long weekend.
I could actually drive my car Friday.. I am unsure what to do with myself.
I have spent $3042. That is suppossed to be everything. Other then my own crossmember ( $30) , thats about it.
Turbo1dr
Post by Turbo1dr » Tue Jan 17, 2006 12:24 am
Off topic... but I see you're from Jacksonville. You ever get to New Bern anytime to the dragstrip or just go to Coastal Plains?
1978 Malibu - Owned since 1986
malihoochie
Post by malihoochie » Tue Jan 17, 2006 6:39 pm
The neutral safety switch from your auto should not be a factor, I was thinking that you may not want to be able to start the car without the the clutch pedal pushed in. I was gonna use a leftover one from my B&M Pro Stick shifter. Did your x-member come in? Also I seem to have a clearance issue with my flasher relay getting hit by my clutch pedal "arm", above the foot pad. :?
"Work in progress"
"Work in progress"
Meat Drapes
Post by Meat Drapes » Tue Jan 17, 2006 8:19 pm
My car was a factory 4 speed. The neutral safety is already in place. I didnt know this untill after I got the tranny in and started it up.
No dice on the crossmember. Mine should be good untill it comes. I did get the drive shaft. The length is correct. I messed up the u-joint measurement. Now I am trying to figure that one out.
I did not know that New Bern even had a drag strip. I just go to Coastal Plains. It gets better and better every year. They even have a tri-oval now if your into that sort of thing.
Post Reply
