I am going to say no, because you need the heads from a 305G. The El Camino only came with a 305H. The G and H are the engine ID in the VIN.
deanz406 said:I've been playing with 305's for quite a few years, mostly with some of the local stock car guys that have to run a 305 in the "Pure Stock" class. There are quite a few combinations that will work well. The most common 305 heads are casting #'s-- 555-434-450-416-601--- and the newer centerbolt heads with #'s 081- 187. Just to clarify some of the numbers-- the 555 casting was used on the very first 305's from 1975-1977, small valve(1.72 X 1.40)-- the 081, and 187 are newer style centerbolt heads, with the 081 having a completely open intake port, and the 187 having the swirl port. Another rather rare casting made in the mid 90's was the 059 casting, and was used exclusively on the 305 Vortec motor, commonly used in pickup trucks. Although they also have a 1.84 X1.50 valve, they can be opened up to a 1.94 X 1.60. They also have a swirl port, but not as profound as the 187 casting. The drawback on these heads is the intake bolt patterns. The 434, and the 450 were later(1978-1982), but were really lightweight castings and most had the 1.72 intake valves, although I have seen a couple 450's with a 1.84 intake. These were VERY prone to cracking, especially in the center where the 2 exh valves are. The 4416, and 601 are the best of the bunch, each having a 1.84 intake. The 416 had decent flow numbers, commonly around 165 CFM, and the 601 usually around 162-163. The comb chamber in the 416 is usually 60 cc, while the 601 is 56-58cc. Like Andy at D&A Machine said, the 601 can be a really hot setup, especially if u open the intakes to 1.94, and exh to 1.60. If u do opt for the 416, or 601, and decide to put a 1.94 in it, it's best to have the chamber unshrouded for clearance around both valves, for good flow results. I have done a couple sets of these, with the big valves, and doing a full competition port job, with excellent results, and some pretty good flow numbers.
I have a 305 built with full flat top pistons, a set of the 601 heads(fully prepped), a comp solid cam- 504 in/ 498 ex-- 248*in/ 254* ex, came out to 11.5-1 comp ratio, Edel RPM Air Gap, 780 Holley-Vac, MSD ign, 1" 5/8 Hooker comp headers, and it dyno'ed 418 HP at 6500 RPM. I have it in a 3200# Regal, TCI 4000 conv, 4:10 gears, and it runs 12.50's all day. It is so easy to make some decent HP numbers, and the Monte SS, and the Camaro Z-28 w/ the 305 HO were rated at 205 HP for a start. You could up that HP, with a RV type cam, a good dual plane intake, headers, and a 600-650 DP carb, good ign, and be around 250-275 HP. This would be the cheapest way to get the HP u are looking for. I have just completed a 334 S/B (305 w/ 400 crank), bored .030, flat top pistons, with same solid cam, 350 Vortec ported heads, Edel RPM Air Gap intake, 750 Holley DP, and will be putting it in the same Regal, and hoping for the low 12's. I think the 305 is a really fun motor to play with, and I'm always looking to build LITTLE motors that GO FAST. Well, Good Luck with ur project-- plan carefully, select the right parts, and you will have a fun ride-- Dean 8)
deanz406 said:80montecarlo-- I just went back to the beginning of the article and looked at ur specs again-- I saw in one u have listed a 3:73 gear, and in the latest one, u have 4:56 gears. I see u listed a 650 D.P., and ur converter is completely inadequate. The converter alone would make a huge difference, and with the 4:56's, a solid cam, Air Gap, and a 750 D.P. carb, you can easily shift around 6200-6400, and click off some low 12's easily. Dean 8)
