RDub355 said:stock block junk
carefull you going to let out all the secrets...
COPO 572 said:1. Did you make the water neck with the extra NPT ports in it, or is it an off the shelf item.
Doober said:And find a new place to mount those gauges :lol:
Actually that's a purty good idea, I may very well do that whenever it comes time for my new motorGot a spare tach & gauges & e'ything
Is that the S-Series truck serpentine setup? I picked one up recently and was kinda curious on the fitment with the stock upper radiator hose.
Jackstand said:RDub355 said:stock block junk
shadychevyowner said:Doober said:And find a new place to mount those gauges :lol:
That serpentine kit is off a 89 caprice. i took off the power steering and put a factory idler where the a/c was and rerouted the belt it turns the water pump and alternator. i like serpentine with self tensioner.. that Water neck is off of the same 89caprice.
Doober said:shadychevyowner said:Doober said:And find a new place to mount those gauges :lol:
The bracket setup I have has the same (or similar) idler, I pulled one with one of those because I don't know how long it will be before (or if) I run A/C with the Gen I motor. My current setup is using a junk compressor as an idler, and I could probably put that idler on, that is if it also fits the bracket setup for a full size Chebby. Is your upper hose a G-Body replacement? I also noticed a square tube radiator support, was yours the one that I saw on here a while back, made it 'cause you were bored/waiting on something/etc.? I also like the diamond plate brackets:lol:
