Throttle cable too short on sbc g body help!!
Damon
1,655
Philly Area
I have my carb sitting on top of a 142 blower (about 4"-5" higher than stock) and the stock cable still reaches. What are you using for a bracket?
Damon
1,655
Philly Area
Got a pic? Those adjustables often have adjustments that aren't obvious or clearly documented, like flipping the throttle cable bracket slider around backwards for more reach. A full inch of difference tells me it's probably some "big change" kind of adjustment that will make the difference here.
Ed Cannon
1,682
Johnson City Tn
10secBu
4,284
Westminster, MD
There is both V6 and V8 cables. I had run a stock V8 cable with my bbc that had a tall Brodix intake, 1 1/2" carb spacer and a dominator carb, V6 cable was too short. I had bought a new stock replacement cable from Advanced Auto I believe.
melloelky
3,654
mass
i recall someone having this problem before and it was solved by a cable from a late 74-79ish chevy pick up w/diesel
