Tremec TKO 600
Meat Drapes
1,198
10
Stoutland, MO
I have $950+ invested in the clutch/flywheel. I wont be changing the size anytime soon. The McLeod 10.4 is pretty good. I am happy with it.
I am pondering a 621 bell and going hydraulic again. Just dont have much money to play with right now.
Meat Drapes
1,198
10
Stoutland, MO
Alright. I have everything lined up for the hydraulic conversion. All parts identified and money is getting consolidated to make the deal.
Only 2 things stand in the way. The John Bdzel clutch pedal and the possibility of having to reinforce the firewall for the clutch master/cylinder.
I emailed John, but no reply yet.
I thought I had seen a template for the firewall but I cant find it anymore. I called Mike Forte and lined up all the parts, he has everything in stock and is ready to ship once I pay.
I think the hardest part will be the clutch pedal alignment to the M/C. Everything else is just labor intensive and VERY EXPENSIVE!! Nearly 1K for this conversion.
Ill take pics of everything.
388bu
3,228
Huntley, il
www.shiftn6.com
Diagram:
And support braces I used from a mid 80's f-body.
Maybe 30k miles and it works flawlessly.
If you buy the right stuff you pay... if you buy cheap stuff you pay eventually... :lol:
I'm guessing you're buying all new parts? Your thread is legend btw :lol: ;) I bet some of the hydraulic guys can shed some light on the reinforcement issue, but I don't think there's that much pressure being put on the firewall. About 3" length of angle iron on either side of the mounting holes would probably be plenty I think, if even required.
Ok... Craig just posted pics... :lol: Looks good 'nough to me ;)
Meat Drapes
1,198
10
Stoutland, MO
Hey Craig,
Your pics are already a fixture on my desktop. Thanks for all of the info and hard work.
Just got the email from John Bdzel. 175 + shipping for the new clutch setup.
Almost ready to start.
388bu
3,228
Huntley, il
www.shiftn6.com
Meat Drapes said:
Hey Craig,
Hey no problem, glad I could help.
I will also add that my clutch pedal is very stiff so I have no doubts that this bracing is adequate for any application. I had to tweak those rods a little bit with a torch IIRC, but they worked out pretty well.
Meat Drapes
1,198
10
Stoutland, MO
Let the Madness begin!!!!
All parts purchased. Going hydraulic and I hope everything works out well.
What do I do about the original hole for the clutch linkage? Does the M/C fit right there? I have seen the template, but have yet to crawl under the dash and really look.
388bu
3,228
Huntley, il
www.shiftn6.com
I am not sure where that hole is. I do recommend cutting the big hole that the M/C goes through first and making sure the geometry is good before drilling the two mounting holes. At least thats how I did it.
