Tremec TKO 600
Most def'nitely!!! It's something to save for though, $5k+ \:D/
http://www.pro-touring.com/forum/showthread.php?t=63513
Meat Drapes
1,198
10
Stoutland, MO
That dogbox T-56 is unreal. Videos on Youtube are pretty interesting.
The Sanderson modification was nothing more then changing the angle of the outlet to a more 'straight' down configuration. Ill post pics.
Meat Drapes
1,198
10
Stoutland, MO
I might have had them move the collector ( if you can call it that) about 25 deg maybe 30.
Meat Drapes
1,198
10
Stoutland, MO
Been driving often. Bangin gears and enjoying the car. The trans suddently feels 'loose' upon shifting. I dont know what a broke in TKO is supposed to feel like but I dont think it should happen all at once. Seems like that from side to side the shifter feels pretty tight. But pushing and pulling it it feels sloppy.
I can only check 3 things when the trans is installed. The shifter handle ,the shift-ball thing that connects to the offset or the shiter itself. Everything else that might be a problem would require the trans be pulled to check. I hope something is loose that can be easily tightened.
Meat Drapes
1,198
10
Stoutland, MO
It edited out shifter? I must have spelled shi tter by accident.
kevind
868
Whitley City KY
I haven't got to drive mine since OCT. I've been super busy with work and just took the trans back out last week the clutch welded to the flywheel. I wouldn't recomend a 4500+ clutch dump in second gear with slicks. I'm waiting on a new clutch to be built.
Meat Drapes
1,198
10
Stoutland, MO
The shifter came loose. All better now.
