Flatblack, the dash is a factory dash and it weighs in at 5 pounds empty with the glove box and the cluster.
406Monte said:Flatblack, the dash is a factory dash and it weighs in at 5 pounds empty with the glove box and the cluster.
elcamino814 said:got them yesterday and man they a light! good lookin piece
2fatties said:Stock a-arm with ball joint 8.4 lbs
Speedway upper front a-arm with Speedway ball joint 4.0 lbs
A-arm description: These 4130 chrome moly metric upper control arms are 40% stronger than standard control arms. They bolt to a stock mount and use the bolt-in style ball joints. Aluminum cross shaft.
Cost of the project from Speedwaymotors.com:
Qty SKU Description Price Total
2 91720045 GM UPPER BALL JOINT $14.99 $29.98
2 91031133-R UPPER METRIC A-ARM,ALUM/STL $47.99 $95.98
1 91016009 PRO-BLEND ANTI-SEIZE $6.99 $6.99
Sub Total: $132.95
Discounts: $0.00
Tax: $0.00
Shipping Total: $9.93
Total: $142.88
Will post pics and how-to article in the next few days if interested..
rollcagerage said:Heres how mine turned out, steel bumpers and stock a-arms and a bbc.
Well, Its a long story but heres a start, http://www.maliburacing.com/forum/viewtopic.php?f=2&t=90388&hilit=door+diet This covers alot of it, basicly just put as much .035 aluminum in it as posible along with tubular frame rails, a powerglide trans really cuts down the weight also along with aerospace brakes and cutting off unneeded frame parts. There is more weight savings yet I could do like lexon windows, glass bumpers, glass trunk lid( I did cutout the inter structure out of the steel trunk) tube upper and lower control arms I'm sure theres another hundred pounds if I did all that. As far as a driver I had my wife sitting in it with a old bench vice in her lap to = close to my weight so I could get the pic. and adjust the suspension.mike from bc said:rollcagerage said:Heres how mine turned out, steel bumpers and stock a-arms and a bbc.
what all is done to get it that light ?? and is that without driver ??
