LIVE4RDO
678
Staten Island, NY
Well... 485 HP and 513 lb ft torque at 5400 RPM. I'm happy.
HOLY TERROR-BU
2,503
WATERBURY, CT
HAD TO CONFRONT THIS STUPID MOTHER****ER! THOUGHT HE THREW A BOTTLE AND BOUNCED OFF MINE! HE IS LUCKY -I WILL **** HIM AND HIS CAR UP!! GONNA BUY A LIGHTWEIGHT BAT THIS WEEK, TO RIDE WITH ME IN THE COCKPIT!! SOMETHING LIGHT...EASY TO SWING...BUT MAKES AN IMPRESSION ON ITS "MARK!"
Bar50
1,871
Tulsa, OK
Oh wow!
Way more exciting than what I got, hope no-one got hurt on the incident.
Fired up the 468 and broke in the cam. Sounds awesome. Took it for a shake down spin around the neighborhood, gonna need a gear, but, its awesome!
StreetBu
4,158
3
Upstate NY
Replaced the blown out l/r wheel cylinder, bled the brakes, realized the master took a cr@p too, replaced that, still no pedal, gotta check out the proportioning valve, think it tripped the internal switch or whatever you call it.
Wicked 6
978
Ansonia, CT
Finally put the radio in the elky...also adjusted the grill and re tighten it so the whistling noise is completely gone \:D/
HOLY TERROR-BU
2,503
WATERBURY, CT
THAT'S GOOD TO HEAR! I KNOW YOU'RE GLAD, YOU DONT GOTTA HEAR THEM ANNOYING SOUNDS!!
fastrat350
3,205
South Texas
www.freewebs.com
installed the motor mounts onto my frame, and yesterday I installed the bench seat
I finally did some work on my '78 after another 2 years or so :roll: The frame is still bare and rusty, I took a grinder with a wire wheel to the scaly rust, getting it ready for a little welding, then paint. I'm really hoping to get the frame painted and ready to set the body on before I head back to Arizona this time around - this means frame painted, hard lines installed, suspension painted and installed, and rearend installed... I don't think the rear would be done because that's kind of a pain to do, but I could at least have the front suspension installed and ready to torque the a-arm bolts.
I also started the '81 so the engine could heat up and hopefully it was idling long enough to vaporize any moisture in the crankcase. I have a feeling the '81 has finally seen its last set of tire marks before I start to tear it apart for the '78 :(
