Tremec TKO 600
388bu
3,228
Huntley, il
www.shiftn6.com
Ugh!
No way you could tap the dowels out a bit to get them to contact the bell? I wonder if someone makes longer dowels?
What timing...I just got in from screwing with my dowels. My runout is way out and I will need the offset dowels. Spent over an hour trying to get the last dowel out. Finally had to drill it, grind it and some careful use of a cold chisel and it finally came out.
Manuals are a PITA sometimes!!! :x
TURNA
6,028
Socialist NY
MOROSO makes different lenth dowels
I think McLeod make an adjustable one
Meat Drapes
1,198
10
Stoutland, MO
Called Quick Time. Got a different person on the phone then when I called Monday. She was much less receptive to the idea of replacement. So I told her I prefered to talk to the other guy ( ROSS). He calls me back during lunch and I explained my problem thoroughly. He suggested longer dowels and stated they could provide an extended pilot bearing.
I politely disagreed and decided to go with the 168T bellhousing. Would thier plan work? Yes. But no thank you.
So Quick Time will take back the bell I bought from Forte and modify it as Forte had done.
Have I really lost anything, no, but I did gain a boatload of knowledge and experience. Would I buy from Quick Time again? I should have in the first place. I do like Forte though.. they sure do try to help and they had the modified bell to begin with.
So perhaps the week of Halloween I should have what I need to get the transmission back in. By then I would like to think I could have the hyd clutch components installed and ironed out. Then again......
StreetBu
4,158
3
Upstate NY
Do you realize that you're just shy of 3 YEARS posting about this trans swap, issues, problems, etc? I dont know how you have lasted this long. I would've either shot myself or thrown the trans away and chalked it up to experience. You are a better man than I!
388bu
3,228
Huntley, il
www.shiftn6.com
I know ive learned a thing or two or eighty about manuals since I put the T56 in this car. They used to be a complete unknown to me, but now id like to think I know a thing or two about 'em.
Good luck Jeff! Keep us posted.
Meat Drapes
1,198
10
Stoutland, MO
Some Progress.
I got the pedals mocked up and drilled the holes for the m/c. Put it all together and everything fit like a glove. I managed to jam a sawzall up under the dash and make the cut/notch on the steering bracket. Took everything out and drilled a hole in the clutch pedal for the ignition lock out. So far so good.
Sent the QuickTime bell back today.
I think tomorrow..maybe.. I could put the booster on and get the pedals and m/c install permanant. Not sure. Sunday is for watching football.
Everything lined up so nice. Too nice in fact. The John Bdzel pedal is just perfect. What a fine job in creating this. The f-body m/c is perfect too. Not as nice as a McLeod peice might be, but it looks as if it will function. At least it does without fluid.
TURNA
6,028
Socialist NY
FOOSE BALL IS FOR THE DEBIL !!!!!
YOU GO FIX UR MALIBU!!!!
Meat Drapes
1,198
10
Stoutland, MO
I installed the the clutch and m/c and components. Instead of building a fancy clutch stop like 388Bu, I left the bolt that holds the m/c connecting rod out about 1/2 inch and the head of the bolt hits the clutch frame/bracket assembly perfectly. I am happy with it and since I have always marched to the beat of my own drum it will be so.
http://webpages.charter.net/jhansen/transmission%20035.jpg
http://webpages.charter.net/jhansen/transmission%20039.jpg
http://webpages.charter.net/jhansen/transmission%20044.jpg
Meat Drapes
1,198
10
Stoutland, MO
On another note, my web provider (Charter) only allows 20 lousy MBs of space and I am maxed out. Ill think of something.
