Tremec TKO 600
Meat Drapes
1,198
9
Stoutland, MO
700r4 I am sorry , but I did not hear you? Cpould you say that again? Worse luck? Turna... I am tyoo hammered to care about anythihng right now. If I coudl start my engne I would nad floor it until the priblenm went awy. 700R4That would takre care of everyhitng. The h e ll with needle bearings, they are noth9ing.
Meat Drapes
1,198
9
Stoutland, MO
I need a new notor anyway, I shopuld make it run and do a burnout that would make eveywone enviouse. And then just buy a new stroker kit. Damn roller rockler peices of cra ap... fail right whern you need them too.
Meat Drapes
1,198
9
Stoutland, MO
Holy cow, orry for the post. I have had seneral too mant.
Killerdave8813
904
Cincinnati,Ohio
Hey Jeff,
Bummer on the needle bearings,Crower I believe has shaft rocker set up that have composite bushings instead of needle baerings,they are pretty expensive but from what i've read here and there work great are quieter that bearing rockers and supposedly less drag as you're not making bearings change directions,makes sense to me,I think you have to do machining to eliminate the rocker stud bosses off the head and that will make the heads usless to anyone not running shaft type rockers but,no studs,guide plates,poly locks,stud girdles,extra tall rocker covers to clear all that stuff and beat of all,no needles!!!!!!!!!!!
If I ever get to the point where I can build the engine I daydream about that's deffinatly the way I'll go,besides a guy named Smokey Yunick that was an engine builder in the old days of Nascar wrote the he absolutly hated GM's Mickey Mouse stud mounted rocker system as there was way to many directions for flexing of the valvetrain and tried his best to get GM to redesign their system,hence all the accessories I previously mentioned,also something you might consider is tha roller lifters also have needle bearings in them,I can't say I know from personal experience but Comp Cams has a solid roller called an EndurX
or something like that that're supposed to be designed for the rigors of street use as a lot of idleing is apparently hard on solid rollers,just thought I'd my 2cents in but it look more like 5 bucks,can't help it,I just seem to get carried away sometimes,by the way I think that's the first time I've seen slurred typing,thought it was pretty cool actually,Good Luck and don't give up! Cars are to much fun when they're right! Later,KillerDave
TURNA
6,028
Socialist NY
Ok MEAT not sure if this is new or old but if it is new... you bring the AR i'll bring the AK and I'll meet you at Keisler's
http://www.chevyhiperformance.com/techarticles/0507chp_keisler_g_body_transmission_swap/index.html
rjleiker
261
Derby, KS
ya, this article has been around for years now, and I guess they figured there wasn't anything to gain from pursuing this idea further... it's like they just let it all just disappear as if it never happened... I talked with them a couple times, and it's like the information never existed... nobody knows anything... it's really frustrating... it wouldn't have taken much more to really make a successful package out if this, but instead, they decided there was "too much variation" over the years of the g-body... so they start putting their eggs in other baskets... even though, with the economy down, g-bodies are now prime real estate for muscle cars, they would be making bank off a project...
oh well... there's my rant... i guess there's always the thought that if we make enough noise, we can get them to start R&D for a new setup... ](*,)
