Tremec TKO 600
Meat Drapes
1,198
10
Stoutland, MO
The TKO came from Keisler this way. Thay also have a crossmember that would work for the Malibu. But you would have to get a frame extension for it. The frame extension is cheap and easy to install.
rjleiker
261
Derby, KS
You don't happen to know what the distance is from your bellhousing (block face) to your shifter do you? or from transmission face of the bellhousing to the shifter?
Just wondering...
rjleiker
261
Derby, KS
ya, I picked that schematic sheet up myself, but his shifter, according to his pictures, is in a different spot... it's, I think, about another 3/4" to 1" forward than the off the shelf shifter at 16.75".
Meat Drapes
1,198
10
Stoutland, MO
Try these pics... one is from directly under the shifter. You can see the original shifter hump outline and how the Keisler shifter sits back and to the driver side.
rjleiker
261
Derby, KS
rjleiker said:
ok, so no icemember made for the TKO. Since I would still have to modify whichever one I buy, I might still get it since it is the simplest and cheapest I've seen.
Did you get that offset shifter from Keisler?
So I talked with Iceman Racing, and gave them a dimension sheet on the TKO transmissions and he said they'd make me one for the same $149 that the others cost.
Just FYI for any of you out there wondering.
Meat Drapes
1,198
10
Stoutland, MO
Car is currently off the road for a solid roller lifter upgrade. PLus it has no heater and its cold outside which makes it no fun to drive.
Meat Drapes
1,198
10
Stoutland, MO
Motor is toast... got needle bearings inside the engine from a failed rocker and they caused all kinds of havoc.
Hope to be back on the road in the fall.... maybe.
TURNA
6,028
Socialist NY
I hate to say it but........finally someone with worse luck than me ](*,)
