pedal feel.....it's a little stiff, I plan to pull it back out someday and move the mounting point up 1/2" to make the ratio better but it's drivable the way it is....rush hour traffic wouldn't be much fun though lol
rjleiker said:
From other installation pics I've seen, it seems that the master cylinder is mounted farther underneath the brake booster, out of the way, and not to the side, like in this hydroboost picture.
I attempted to wrap my head around making a tilton work with the vacuum booster but never did figure out a way to do it easily and effectively, remember the farther away you attach the M/C from the pivot point of the clutch pedal the stiffer the pedal is, to get the M/C below the booster it would require you to angle it up like the f-body M/C or have a hugemongous leg...
plus the hydroboost is the absolute best thing I've done to the car as far as brakes go...I've got the 12" upgrade in the front and LS1 F-Body 12" discs in the back, the old setup with a electric vacuum pump, a vacuum reservoir, trying to work the dual diaphram booster doesn't even come close to the amazing brakes I have now
and as far as the hydroboost robbing power.....it doesn't take any more away than the normal power steering pump does....I'm using the exact same pump as before I just changed the housing so it has two return lines....
ask more questions and I'll try to answer, Craig picked my brain long ago lol
oh, headers are Hooker 2455's that I modified the pass side to make fit better and then had coated
