Tko or m23
KingLevi
51
Louisville, KY
Switching to manual trans
Can't decide tko 600 with shift mods or auto gear m23
Bench seat car 11.1 built 406sbc shift 6500 max rpm 6800 3.90gear/3.42(have both)
Weekend toy 1/8 mile once in awhile hwy driving 25% time
Probably hyd clutch
Which would you choose
Thanks
TURNA
6,028
Socialist NY
I run a custom T56 so I would go with the TKO if those were the only 2 choices
Overdrive will make it much more highway-friendly.
Do you mean M22?
TURNA
6,028
Socialist NY
M23 is a "new updated" version on the M22
Yup. AGE now calls their redisegned Muncies "Syracuse" 4 speeds. The M23 is the severe duty version.
After a lot of soul searching I am moving away from my M21 to a Legend LGT700. I looked at a lot of the other 5 speeds. Seems most don't like high rpm shifts, have synchro issues with fast shifts and just don't drive like a Muncie. The Legend seems to answer all those issues. After driving one I wholeheartedly recommend it. After you get done spending the money to modify the production style 5 speeds you're only a little bit away from the Legend.
KingLevi
51
Louisville, KY
Will tko bolt to iceman th350 crossmember? Thought someone from Texas did this
Anyone shift over 6500 without upgrade tko
Hydraulic cylinder and clutch pedal recommend
Thanks
kevind
868
Whitley City KY
I have a TKO600 mechanical linkage old style Chevy Lakewood bell housing not the odd ball Malibu one. Home made crossmember I think my motor is lower in the back than it was with the Muncie because the TKO is really close to the trans tunnel. TKO doesn't shift as good as the Muncie did but it doesn't sound like the rods are going to fly out of the motor driving on the highway either.
kevind
868
Whitley City KY
G body linkage probably has a extra hole drilled in it. Std Chevy Lakewood bellhousing and fork. Bucket seats.
